Modify the FROM URI in the SIP INVITE message.
We need to modify the FROM URI in the SIP INVITE message.
Currently, the FROM URI is sent as:
sip:84.56.12.47
We need it to be sent as:
sip:01169122290@84.56.12.47
If any specific configuration is required on Dialogic, please share the details or recommended settings , or from voice guide
Can you please post the VoiceGuide and WireShark traces capturing the system startup and the call attempt. We can then see what is happening on the system and advise.
VoiceGuide traces are in VoiceGuide's /log/ subdirectory.
SECURITY_NOTE: Please change the password used on the SIP account after posting any WireShark traces that capture SIP registrations or call authentications. Otherwise, if password is too simple, it can be cracked from the posted WireShark trace. If other parties crack your password then they may be able to start making calls through your account, which can result in large call charges on your SIP account.
